Part Number: DP83869HM
Hi team,
My customer is thinking of using DP83869HM in their project and had the following questions.
- Our application is a media converter between 1000BASE-X and 1000BASE-T. From the data sheet, I believe we can achieve this by using hardware strapping and no software/firmware is required. Is this understanding correct?
- The data sheet states the latency is low but only the latency from RGMII < - > Cu is given. Would you know if there is a latency number for the Fiber < - > Cu?
- From the data sheet, there is a total output jitter of 192 ps for the 1000BASE-X, would there be a breakdown between Rj and Dj from that total jitter? Also, is there any jitter tolerance number for the 1000BASE-X input?
- Would TI sell this part in die form?
Thank you in advance for your support!
Errol
