Part Number: TFP410
Hi team,
Could you please support the below datasheet info request (active project at assigned customer):
I’m currently looking at the TFP410 Datasheet and in particular about driving the IDCK in a differential configuration. However, it doesn’t seem clear what the thresholds are for the differential setup. It’s clear for the CMOS input type but not for the differential.
I’m looking for the following parameters:
- IDCK VCM (voltage common mode) – I assume this to be set by Vref on the device
- IDCK Vih (Voltage In High)
- IDCK Vil (Voltage In Low)
- IDCK Swing voltage – might be more appropriate
The datasheet is explicit in the CMOS input configuration but not the differential mode. I want to ensure we set the port on the PLD to the correct setting so we don't violate the datasheet specifications, nor introduce marginal stability in the system.
Thanks and best regards,
Dan
