Part Number: DP83TD510E
Hi all
Would you mind if we ask DP83TD510E?
DP83TD510E is for 10Base-T1L Ether Phy.
10Base-T1L doesn't correspond for multi drop connecition.
If we configure multi drop with 10Base-T1L, we assume that it requires Hub or Ethernet swtich.
In case of using Hub or Ethernet swtich, does it need to use Hub or Ethernet swtich which corresponds for 10Base-T1L?
Or, is it possible to use normal 10Base-T hub??
Kind regards,
Hirotaka Matsumoto
