Part Number: DS250DF230
Hi Team,
Would you pls help to check how to handle unused RX&TX pin of retimer? Thanks a lot!
Is it ok for below terminated circuit?
B.R.
Zhizhao
Hi Team,
B.R.
Zhizhao
The user may either leave these unused high-speed pins floating or terminate them to GND. Note that TI supports the implementation of a retimer channel full power down register write routine. When this channel power down is applied, the hardware configuration of unused pins is even less critical.
Rodrigo Natal
HSSC Applications Engineer
Hi Rodrigo,
Thanks a lot.
If I terminate them to GND, what value of resister is recommended? Is there a document describing that? If yes, would you pls send it to me? Thanks a lot!
B.R.
Zhizhao
