Part Number: TPS65981
Other Parts Discussed in Thread: TPS65983B
Hi.
In the TPS65981 datasheet under "Port Power Switch Characteristics", it lists the current limits for PP_HV for different settings. However, I can't find the corresponding setting either in I2C-accessible registers or in the Application Customization Tool.
The E2E thread https://e2e.ti.com/support/interface/f/138/t/862719 indicates that the current limit is hardwired and cannot be set on the TPS65983B. Is that also the case for the TP65981? If not, how is it set?
In either case, can I determine what the setting is?
Steve
