Dears
Can the MDI interface adjust the drive current or drive voltage?
Elsa Duan
Dears
Elsa Duan
Hi Elsa,
DP83867 is a voltage mode driver there is no current drawn from magnetics of PHY
Cecilia
Hi Cecilia
Thanks for your result.
In fact, what I want to know is whether the MDI port can adjust the voltage amplitude?
There is a problem with the test. The peak voltage of the test template that comes with the oscilloscope is too high and False appears.
I want to try to adjust. How to achieve it?
Elsa Duan
Cecilia is currently out of office and will respond back tomorrow.
Adrian Kam
Hi Elsa,
Have you confirmed your RBIAS is at 1% tolerance? That can affect the peak output voltage. Can you also please clarify which test exactly is failing in compliance?
Cecilia
