Part Number: TPS65988DJ
Other Parts Discussed in Thread: TPS65988,
I am using TPS65988 based design. Can I use it as a standalone without Master I2C?
Hi Baghiya,
Yes you may, it's not necessary to have a Master I2C connected to the TPS65988DJ. However, if you are planning to use it for certain applications like TBT, then you may need to implement a Host.
Also, if you don't have a Master I2C or a Host, typically we recommend having a Flash on board though so that you may program the PD controller to your desired configurations.
Thank you,
Hari
