Part Number: TUSB8044A
Hi Team
We are using TUSB8044A we are getting following following log during kernel initialization
[ 0.000000] Kernel command line: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt u0
[ 0.755777] GPIO line 429 (usbhub-reset) hogged as output/high
[ 0.755812] GPIO line 428 (led-hub) hogged as output/high
[ 0.818866] usbcore: registered new interface driver usbfs
[ 0.818922] usbcore: registered new interface driver hub
[ 0.819051] usbcore: registered new device driver usb
[ 0.885148] vdd-usb-3v3: at 3300 mV
[ 1.463760] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 1.801769] usbcore: registered new interface driver r8152
[ 1.801818] usbcore: registered new interface driver asix
[ 1.801877] usbcore: registered new interface driver ax88179_178a
[ 1.801910] usbcore: registered new interface driver cdc_ether
[ 1.801941] usbcore: registered new interface driver net1080
[ 1.801970] usbcore: registered new interface driver cdc_subset
[ 1.802002] usbcore: registered new interface driver zaurus
[ 1.802056] usbcore: registered new interface driver cdc_ncm
[ 1.802086] usbcore: registered new interface driver cdc_mbim
[ 1.803692] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.803789] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.808769] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 1.810804] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f4d15800 id
[ 1.811110] usbcore: registered new interface driver cdc_wdm
[ 1.811187] usbcore: registered new interface driver uas
[ 1.811239] usbcore: registered new interface driver usb-storage
[ 1.811357] usbcore: registered new interface driver usbserial
[ 1.816445] tegra-xusb 3610000.xhci: Firmware timestamp: 2019-07-24 05:47:34 UTC, Version: 60.06 release
[ 1.816485] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.816537] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 1.816576] usbcore: registered new interface driver xpad
[ 1.817272] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 1.817318] tegra-xusb 3610000.xhci: irq 464, io mem 0x03610000
[ 1.817677] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.817685] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.817691] usb usb1: Product: xHCI Host Controller
[ 1.817698] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.817703] usb usb1: SerialNumber: 3610000.xhci
[ 1.818172] hub 1-0:1.0: USB hub found
[ 1.818232] hub 1-0:1.0: 4 ports detected
[ 1.818974] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.818986] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 1.818996] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.819359] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.819367] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.819373] usb usb2: Product: xHCI Host Controller
[ 1.819379] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 1.819384] usb usb2: SerialNumber: 3610000.xhci
[ 1.819807] hub 2-0:1.0: USB hub found
[ 1.819849] hub 2-0:1.0: 4 ports detected
[ 2.003569] usbcore: registered new interface driver usbhid
[ 2.003574] usbhid: USB HID core driver
[ 2.021565] usbcore: registered new interface driver snd-usb-audio
[ 2.142732] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.163290] usb 1-2: New USB device found, idVendor=0451, idProduct=8442
[ 2.163297] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 2.163302] usb 1-2: SerialNumber: 1D000069C998
[ 2.164142] hub 1-2:1.0: USB hub found
[ 2.164209] hub 1-2:1.0: 6 ports detected
[ 2.450702] usb 1-2.5: new high-speed USB device number 3 using tegra-xusb
[ 2.471115] usb 1-2.5: New USB device found, idVendor=0451, idProduct=82ff
[ 2.471121] usb 1-2.5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.472806] hid-generic 0003:0451:82FF.0001: hidraw0: USB HID v1.11 Device [HID 0451:82ff] on usb-3610000.xhci-2.5/input0
[ 5.141145] usb0: HOST MAC 1a:da:05:a7:b3:ee
[ 5.141292] usb0: MAC 1a:da:05:a7:b3:ef
[ 5.178250] l4tbr0: port 2(usb0) entered blocking state
[ 5.178258] l4tbr0: port 2(usb0) entered disabled state
[ 5.179453] device usb0 entered promiscuous mode
[ 5.189939] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 5.993799] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 5.993806] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 6.318966] usb 2-3: new SuperSpeed USB device number 2 using tegra-xusb
[ 6.340494] usb 2-3: New USB device found, idVendor=0451, idProduct=8440
[ 6.340504] usb 2-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 6.342195] hub 2-3:1.0: USB hub found
[ 6.342275] hub 2-3:1.0: 4 ports detected
[ 6.506752] usb 2-3: usb_suspend_both: status 0
[ 6.507034] usb usb2: usb_suspend_both: status 0
Logs after inserting pen drive on hub
anycon@tegra-ubuntu:~$ [ 265.219424] usb 1-2.3: Device not responding to setup address.
[ 265.427463] usb 1-2.3: Device not responding to setup address.
[ 265.634826] usb 1-2.3: device not accepting address 4, error -71
[ 265.715554] usb 1-2.3: Device not responding to setup address.
[ 265.923423] usb 1-2.3: Device not responding to setup address.
[ 266.130778] usb 1-2.3: device not accepting address 5, error -71
[ 266.814883] usb 1-2.3: device descriptor read/64, error -32
[ 267.002957] usb 1-2.3: device descriptor read/64, error -32
[ 267.270877] usb 1-2.3: device descriptor read/64, error -32
[ 267.458891] usb 1-2.3: device descriptor read/64, error -32
[ 267.567052] usb 1-2-port3: unable to enumerate USB device
Please let me know following
1) We are getting two product id for same vendor ID ? Is it correct ? why we are getting two product id ?
2) During enumeration what should be step/ sequence ?
3) We checked We are getting VBUS 5V , in-fact glowed discrete LED. But neither USB mouse nor USB SD card LED is glowing. Does these led should glow after getting enumeration successful.?
4) Regarding PWRCTRL how , it will be driven ie does it will be always remain ON or OFF based on active low or high setting? Or it will be driven based on what kind of device is getting connected ? I am
getting voltage on VBUS even when no device is connected.
5) Does enumeration has any dependency on VBUS.
6) Can we read and wrte registers over USB if yes then how ?
