Part Number: TUSB2046B
Hi Team,
This is customer request, can you please advise?
We use TUSB2046B on one of our cards. When we connect Flash Memory and touch panel card to this USB HUB, we get an error "Rejected One Configuration Due To Insufficient Available Bus Power". However, when we connect the same devices to the ports of this HUB via another USB HUB, the devices work. It also works when connected directly to the USB port of the CPU. It does not work when we supply the devices connected to the ports with + 5V from the outside. We couldn't figure out why. Could you help?
Thanks in advance
Best Regards
Furkan Sefiloglu
