Part Number: TS3USB221E
Dear Team,
Could you help to elaborate more details about the charge pump?
I cannot find it in the spec.
What is the purpose of it?
Thank you.
Jim
Dear Team,
Thank you.
Jim
The device internally uses NFET switch in the data path. Typically The switch is driven at higher voltage at its gate to be able to pass I/O signals. This device supports higher I/O voltage compared to the supply voltage. This requires that we have an elevated voltage that is generated by an internal charge pump circuit.
