Part Number: DP83867IR
Regarding "PHY has detected a Receive Error." In the data sheet P10,
Please tell me when an error occurs.
Is there any document that describes it?
The PHY may detect a receive error when there is a decode error, a packet cannot be decoded by the PCS. This is basically a packet error indication.
Thank you,
Nikhil
Hello,Nikhil-san
Thank you for your answer.
What are the possible causes of decoding errors?
Also, if a link has not been established with the link partner
Will this error occur?
Are carrier expansion errors included in this error?
Furthermore, what kind of error is a carrier expansion error?
We are looking into your questions and will provide feedback by Friday.
Thank you,
Nikhil
There can be several sources of decoding errors, including signal integrity issues, EMC/EMI issues, or clock issues. If there is no link, there should be no packets received, thus there cannot be a receive error.
Thank you,
Nikhil
The PHY is not capable of forcing an error manually without an actual receive error event occurring.
Thank you,
Nikhil
Hi Nikhil-san
I am trying to see if RX_ERR can be observed using VQFN pin 39 (GPIO_0), but there is no response.
Does this function not work in RGMII mode?
RX_ER pin is unused in RGMII mode. The Pin Functions table in Section 6 of the datasheet describes how pins are used in each mode.
If you have any further questions, feel free to open a new thread.
Thank you,
Nikhil
