Part Number: TUSB7340
Hi Team,
Customer has quick question regarding to our datasheet 1st page description.
Each Downstream Port – May Be Marked as Removable or Nonremovable
What is this meant?
Thanks!
Andrew
Hi Team,
What is this meant?
Thanks!
Andrew
Hi Andrew,
If TUSB7340 is used in a application where the downstream USB port is directly connected to internal USB PHY with no externally facing USB connector, the port should be marked as non-removeable. This is done by USBx_PORTx_NON_REM bits.
FYI, TUSB73x0 is NRND and has very limited support. Please be sure to read over the errata for this device.
