Part Number: TUSB4020BI
We operate TUSB4020BI with an internal power supply instead of VBUS.
In what order should we turn off VDD33 and VDD when the power is off? And should GRTSTz be set to Low level at that time?
A correct power-up sequence is more important than the power down sequence, no specific power down sequence is required. If you are using a passive reset then GRSTz will be low once VDD3 is removed. If you are using a active reset I recommend GRST be low just before power down.
