Hi expert,
My customer use DSLVDS1048/1047 to transmit signal. Do you know what's the largest transmission distance that DSLVDS1048/1047 could support? And is there any methods that could increase the transmission distance? Thanks!
- Jared Liu
Hi expert,
- Jared Liu
Hi Jiandong,
Maximum transmission distance is a system dependent parameter depending on my factors like data rate, cable quality, trace length, tolerable signal distortion, tolerable jitter, etc. so we cannot provide a definitive answer to this question. Typically it can handle <5 m at 400 Mbps with good system design, but it'd be best for the customer to prototype it in their system with their conditions to determine the max distance.
I.K.
Hi Anyiam,
Thanks for your support. Do you know what kind of cable is more suitable for long distance transmission? Thanks!
- Jared.
Hi Jared,
Cat5e cables will work well. You can find a test report here: https://www.ti.com/lit/an/slaa844/slaa844.pdf
I.K.
