Part Number: TUSB4041I
Dear Support Team,
Our company has developed a control card using 3 pcs of TUSB4041I hub and some other IC-s. It works very well except for one issue: I wanted to indicate the high-speed USB connection status of the upstream port of each hub by a LED, but I couldn't enable this feature. The Pin Configuration and Functions section of the datasheet tells the following about the related pin:
Let's see the Additional Feature Configuration Register section:
I couldn't find any information neither in the register description, nor in other parts of the datasheet about how to enable this feature. We have made some more developments and I would like to fix this issue in the next version of the PCB. Please help me how to fix it. According to the datasheet I/O pins can be used up to 4 mA output current, so the indicator LED can be driven from this pin directly. Is it true for this special function pin too?
Thank you in advance.
Balazs Soregi
