Part Number: DP83867IR
Other Parts Discussed in Thread: USB-2-MDIO
Can you please point me to the documentation that describes how to connect and configure the DP83867IR using MII? We are connecting to an AM65xx processor.
We are working on a industrial protocol project and apparently the EtherCAT stack requires MII only.
We would like to be able to configure the ethernet port dynamically to switch between MII and RGMII so that the same port could be used for other, more standard purposes.
It looks like the pin functions table of the data sheet describes the MAC interface assignments- is that all there is to go on?
Should we forgo RGMII and just try to switch between MII and GMII to get the higher speed when needed?
Does the GUI tool explain all of the register settings required?
(sorry for some of the basic questions... I'm pretty new to these devices)
Thanks, Best, Steve
