Part Number: DP83869HM
Other Parts Discussed in Thread: USB-2-MDIO, DP83869EVM
Good day,
My customer is trying to get recovered clock from RX stream for syncE. They are experimenting with DP83869EVM with default settings (OPMODE = 000, DIP switch = 0000). Changing CLK_O_SEL bits of IO_MUX_CFG register (0x170) via USB-2-MDIO software don't lead to expected behavior. Clock on CLK_OUT pin is always remain 25MHz and not in sync with received data. Setting CLK_O_DISABLE bit actually disable clock. Which settings should they apply to get recovered clock from ethernet link?
Thank you,
Daria
