Part Number: AM26C31
Other Parts Discussed in Thread: AM26C32
I would like you to ask whether you have ever had an experience about following phenomenon.
* We rarely observe that output from "Y" pin and "Z" pin are same polarity.
According to datasheet, when "G" pin connect to GND and input low level signal to "Gn" pin, we must see following behavior.
* When "A" pin input is "low" level, "Y" pin output should be "low" level and "Z" pin output should be "high" level against common mode voltage.
However, we rarely observe when "A" pin input is "low" level, "Y" pin output is "low" level but "Z" pin output is also "low" level(This means we can not get inverted output.).
Q1, Have you ever observed same phenomenon ?
Q2, If answer of Q1 is yes, what was root cause ?
Q3, If answer of Q1 is no, what do you think I should investigate to understand root cause of this phenomenon ?
