Part Number: SN65DSI84
I want to ask the following question:
Was it adjusting the SOC which CLK? is DSI CLK?
Because we have the same problem, thanks!
If panel flickering is an issue then yes it may be the DSI CLK. You should first check that you're programming the DSI84 correctly by following this FAQ: https://e2e.ti.com/support/interface/f/138/t/918890
Then check number 2 - 4 on this FAQ if you still have issues: https://e2e.ti.com/support/interface/f/138/t/852871
I.K.
