Part Number: DS90UB960-Q1
Other Parts Discussed in Thread: DS90UB933-Q1
Hi team,
We have four camera(with DS90UB933-Q1 inside) connect with one 960. They work well most of the time, but occasionally the 960 failed to send data, especially when running the app for the first time after power on. All the register values have been read out and put in the attachment(0x50-0x53 are the I2C address of DS90UB933-Q1).
My question is: What is probably the reason for this? Any clues are greatly appreciated.
Thanks!
root@clr-46d3c2270efb4ce89da59d264cdab0cf ~ # i2cdetect -r 5
WARNING! This program can confuse your I2C bus, cause data loss and worse!
I will probe file /dev/i2c-5 using receive byte commands.
I will probe address range 0x03-0x77.
Continue? [Y/n] y
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: UU -- -- -- -- -- -- -- -- -- -- -- -- UU -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: 50 51 52 53 -- -- -- -- 58 -- 5a -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
root@clr-46d3c2270efb4ce89da59d264cdab0cf ~ # i2cdump -f -y 5 0x50
No size specified (using byte-data access)
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: b0 30 20 c5 80 14 60 00 00 00 04 00 17 55 35 00 ?0 ???`...?.?U5.
10: 17 82 82 00 00 31 80 00 00 00 00 00 00 a0 fe 00 ???..1?......??.
20: 0e 1c 29 00 00 00 00 00 25 06 00 00 00 00 00 00 ??).....%?......
30: 00 00 00 fe 80 01 00 00 00 00 00 00 00 00 00 00 ...???..........
40: b0 30 20 c5 80 14 60 00 00 00 04 00 17 55 35 00 ?0 ???`...?.?U5.
50: 17 82 82 00 00 31 80 00 00 00 00 00 00 a0 fe 00 ???..1?......??.
60: 0e 1c 29 00 00 00 00 00 25 06 00 00 00 00 00 00 ??).....%?......
70: 00 00 00 fe 80 01 00 00 00 00 00 00 00 00 00 00 ...???..........
80: b0 30 20 c5 80 14 60 00 00 00 04 00 17 55 35 00 ?0 ???`...?.?U5.
90: 17 82 82 00 00 31 80 00 00 00 00 00 00 a0 fe 00 ???..1?......??.
a0: 0e 1c 29 00 00 00 00 00 25 06 00 00 00 00 00 00 ??).....%?......
b0: 00 00 00 fe 80 01 00 00 00 00 00 00 00 00 00 00 ...???..........
c0: b0 30 20 c5 80 14 60 00 00 00 04 00 17 55 35 00 ?0 ???`...?.?U5.
d0: 17 82 82 00 00 31 80 00 00 00 00 00 00 a0 fe 00 ???..1?......??.
e0: 0e 1c 29 00 00 00 00 00 25 06 00 00 00 00 00 00 ??).....%?......
f0: 00 00 00 fe 80 01 00 00 00 00 00 00 00 00 00 00 ...???..........
root@clr-46d3c2270efb4ce89da59d264cdab0cf ~ # i2cdump -f -y 5 0x51
root@clr-46d3c2270efb4ce89da59d264cdab0cf ~ # i2cdump -f -y 5 0x52
root@clr-46d3c2270efb4ce89da59d264cdab0cf ~ # i2cdump -f -y 5 0x53
00: b0 30 20 c5 80 14 60 00 00 00 ff ff 17 55 35 00 ?0 ???`.....?U5.
40: b0 30 20 c5 80 14 60 00 00 00 ff ff 17 55 35 00 ?0 ???`.....?U5.
80: b0 30 20 c5 80 14 60 00 00 00 ff ff 17 55 35 00 ?0 ???`.....?U5.
c0: b0 30 20 c5 80 14 60 00 00 00 ff ff 17 55 35 00 ?0 ???`.....?U5.
root@clr-46d3c2270efb4ce89da59d264cdab0cf ~ # i2cdump -f -y 5 0x30
00: 60 00 1e 40 d0 01 00 fe 1c 10 7a 7a 0f b9 0e ff `.?@??.???zz???.
10: 91 85 89 8d 00 00 00 00 03 00 00 05 6c 00 04 00 ????....?..?l.?.
20: 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .?..............
30: 00 00 01 43 01 00 00 03 00 00 00 00 00 00 00 00 ..?C?..?........
40: 00 a9 71 01 00 00 20 00 00 00 00 12 38 d3 55 31 .?q?.. ....?8?U1
50: 80 00 00 00 00 00 00 00 58 00 00 b0 a6 00 00 00 ?.......X..??...
60: 00 00 00 00 00 00 00 00 00 00 00 00 00 7f aa 88 .............???
70: de ec e7 02 d0 0a 00 c5 00 01 00 00 e0 00 00 00 ??????.?.?..?...
80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
90: 1e 4e 1e 4e ff ff ff ff 00 00 00 00 00 00 00 00 ?N?N............
a0: 00 00 00 00 00 1b 00 00 00 00 00 00 00 00 00 00 .....?..........
b0: 14 04 04 08 25 00 18 00 88 33 83 74 80 00 00 00 ????%.?.?3?t?...
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
d0: 00 43 94 02 60 f2 00 02 00 00 00 10 00 00 00 00 .C??`?.?...?....
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
f0: 5f 55 42 39 36 30 00 00 00 00 00 00 00 00 00 00 _UB960..........
00: 60 00 1e 40 d0 01 00 fe 1c 10 7a 7a 0f b9 0f ff `.?@??.???zz???.
30: 00 00 01 43 01 00 00 00 00 00 00 00 00 00 00 00 ..?C?...........
40: 00 a9 71 01 00 00 20 00 00 00 00 12 38 c3 14 31 .?q?.. ....?8??1
90: 02 50 02 50 ff ff ff ff 00 00 00 00 00 00 00 00 ?P?P............
root@clr-46d3c2270efb4ce89da59d264cdab0cf ~ # i2cset -f -y 5 0x30 0x4c 0x01
40: 00 a9 71 01 00 00 20 00 00 00 00 12 01 13 5d 31 .?q?.. ....???]1
50: 80 00 00 00 00 00 00 00 58 00 00 b0 a0 00 00 00 ?.......X..??...
70: 1e 2c e4 02 d0 0a 00 c5 00 01 0f ff e0 00 00 00 ?,????.?.??.?...
90: 06 b0 06 b0 ff ff ff ff 00 00 00 00 00 00 00 00 ????............
40: 00 a9 71 01 00 00 20 00 00 00 00 12 01 03 14 31 .?q?.. ....????1
70: 1e 2c e4 02 d0 0a 00 c5 00 01 00 00 e0 00 00 00 ?,????.?.?..?...
90: 01 24 01 24 ff ff ff ff 00 00 00 00 00 00 00 00 ?$?$............
root@clr-46d3c2270efb4ce89da59d264cdab0cf ~ # i2cset -f -y 5 0x30 0x4c 0x12
40: 00 a9 71 01 00 00 20 00 00 00 00 12 12 53 5d 31 .?q?.. ....??S]1
50: 80 00 00 00 00 00 00 00 58 00 00 b0 a2 00 00 00 ?.......X..??...
70: 5e 6c e5 02 d0 0a 00 c5 00 01 0f ff e0 00 00 00 ^l????.?.??.?...
90: 03 a0 03 a0 ff ff ff ff 00 00 00 00 00 00 00 00 ????............
40: 00 a9 71 01 00 00 20 00 00 00 00 12 12 43 14 31 .?q?.. ....??C?1
70: 5e 6c e5 02 d0 0a 00 c5 00 01 00 00 e0 00 00 00 ^l????.?.?..?...
90: 00 8c 00 8c ff ff ff ff 00 00 00 00 00 00 00 00 .?.?............
root@clr-46d3c2270efb4ce89da59d264cdab0cf ~ # i2cset -f -y 5 0x30 0x4c 0x24
40: 00 a9 71 01 00 00 20 00 00 00 00 12 24 93 5d 31 .?q?.. ....?$?]1
50: 80 00 00 00 00 00 00 00 58 00 00 b0 a4 00 00 00 ?.......X..??...
70: 9e ac e6 02 d0 0a 00 c5 00 01 0f ff e0 00 00 00 ??????.?.??.?...
90: 03 f0 03 f0 ff ff ff ff 00 00 00 00 00 00 00 00 ????............
40: 00 a9 71 01 00 00 20 00 00 00 00 12 24 83 14 31 .?q?.. ....?$??1
70: 9e ac e6 02 d0 0a 00 c5 00 01 00 00 e0 00 00 00 ??????.?.?..?...
90: 00 b8 00 b8 ff ff ff ff 00 00 00 00 00 00 00 00 .?.?............
Connection was reset.
