Part Number: DP83TG720S-Q1
Hi Team,
My customer is designing an Automotive connectivity module project now.
I found customer use below PHY solution in design.
So, do you think we have suitable solution or you have any suggestion that we can replace following customer solution ? Q grade is necessary.
Customer solution now |
TI proposal |
100BASE-T1 /1000BASE-T1 Single-Port Automotive Ethernet Transceiver |
BROADCOM |
single pair Ethernet physical layer transceivers (PHYs) |
Marvell |
BCM89881 : https://www.broadcom.com/products/ethernet-connectivity/automotive/phy/bcm89881
88Q2112 : https://www.avnet.com/wps/portal/silica/products/product-highlights/2017/marvell-88q1010-88q2112/
You can contact me directly by email : kai.lai@ti.com
Thank you !
Kai Lai
