Part Number: DP83822I
Hi Team
Can I ask for the max current consumption for each rails?
Thanks!
Andrew
Hi Team
Thanks!
Andrew
It's RGMII to RJ45, and customer uses 3.3V for both VDDIO and AVDD, thanks.
Andrew
Hi Andrew,
The datasheet table you have seen on page 98 specs power consumption for nominal supply voltage at 25C and thus may not be true max consumption (conditions are not max temp and max supply rail voltage). I am looking into the max power consumption and will provide additional feedback by next week.
Thank you,
Nikhil
Hi Andrew,
In the Datasheet page mentioned, you may refer to the test condition labeled for high temp (125C) for max current at nominal voltage.
Thank you,
Nikhil
