Part Number: DP83822H
According to Table 1 in the datasheet, on reset, MDC is a pull-down. I have reached out to the appropriate party to confirm pin status and pull value. I will be able to provide an update next week.
Thank you,
Nikhil
Hello Nikhil,
There is no such table in the datasheet.
Please refer to the attached datasheet we are referring..
Thanks for the follow up. Replies on E2E are delayed due to end of year holidays. We will get back to you by Jan 7.
-Regards
Aniruddha
Apologies for the confusion, it looks like the datasheet you have attached is an older version. The datasheet linked here is the latest version, version E:
Table 1 in section 6.1 describes the pin states in reset. I have reached out to our design team to determine the value of the internal pull and will provide an update by the end of the week.
Thank you,
Nikhil
Internal pull-value should be 9k +/- 25%. May I ask why pull value of MDC is needed?
Thank you,
Nikhil
Why such strong pull value of 9K inside? Why this information not present in datasheet?
Generally internal pull down value will be more than 50K in most of the device. Many are of 100K as internal pulls.
We are looking into your question and I will provide an update by Friday of this week latest.
Thank you,
Nikhil
Hi Kalpesh,
Apologies for the delay and for my miscommunication. In section 7.5, the last 3 rows of the table show the integrated pull resistor values and tolerances. 50k would be too weak a pull value, the line may pick up additional noise. Please let me know if you have any further questions.
Thank you,
Nikhil
