Part Number: DP83848-EP
Having similar issue as others where upon power up the ethernet phy is unable to establish a link. Cycling the power seems to cause the chip to work or not about 50% of the time. We are using hardware strapping to setup the device. Sounds like same issue as "DP83848-EP: PHY Component Intermittently Powering up in Bad SSD Mode" but did not see a solution for the issue. Any help would be appreciated.
