Hi Team,
Datasheet mentions that DP[3:0]P/N pairs should be routed with controlled 90-Ω differential impedance (±10%). If for some reason my customer will have to make it 85-Ω differential impedance (±10%), will it be acceptable?
Thanks!
Roy
Hi Team,
Thanks!
Roy
Hi Roy,
Routing the DP lanes at 85-Ω differential impedance (±10%) is not recommended. If routing at 85-Ω differential impedance, tolerance should be less than 5% to keep the range inside the 90-Ω differential impedance (±10%) range.
