Part Number: TS3DV642
Hi
We are using a TS3DV642 chip, and we have encountered some problems and need to consult you. Please help to see how to solve this problem.
Description of the problem phenomenon: There is a button on our device to switch the display of channel 1 or channel 2. Before powering on, we dial the button to channel 1 to display and then power on, then it can display normally. At this time, if you switch the button to channel 2, the display will be abnormal, and there will be a prompt on the display, as shown in the figure below. If you switch the button to channel 2 before powering on and then power on, the display can also be normal at this time. At this time, if the button is dialed to channel 1, the display is abnormal, and a prompt will pop up on the display. The display information is also displayed as shown in the figure below. What causes this phenomenon and how to solve this problem. Please provide a solution to us.We also want to know if this chip supports HDCP.
