Part Number: TVP7002
My customer has an existing project with the TVP7002. They are seeing what looks to be a bug, but I can't find the errata for this part to verify. Can you point me to it? The potential bug is described below.
"TVP7002 is set up to output Data Enable (Misc Control 2: Test Output Control = 001b).
The Data Enable works fine except that it truncates the last few pixels of the last line of every frame. For example, for 1920x1200 resolution, the Data Enable will be valid (true) for 1920 pixels for each line, except the last line, where it’s valid for only 1916 pixels. This wreaks havoc on our compression engine which requires the correct number of pixels for each frame. I’ve spent a couple of days trying everything I could but the Data Enable always functions like this, regardless of the resolution or programming.
Maybe I’m missing something and someone else has seen this and found a fix? "
Tom
