Other Parts Discussed in Thread: , ISO7761
Hi Support team
due to MUC is no CAN FD interface, my customer would like use TCAN4550 + ISO communication to achieve CAN FD interface
however, few questions need your advice
- If use CAN with 1Mbps, how to set the SPI baud rate? Crystal be still 40MHz?
- Need your help to advise 6 channels isolator to match baud rate of item1.
- The register map seems to be complicated to set, can you provide a simple way to do? (or what is the key register that must be set)
- the following structure works
thanks a lot
