Part Number: TUSB217-Q1
Other Parts Discussed in Thread: TUSB217EVM
Hi team,
does the TUSB217-Q1 have USB-IF authentication, Can you share the report? thanks.
Hi team,
Hi Betty,
USB2 redriver are not tested sperate for the systems unlike USB 2 Hubs (no TID). Please find below a example eye diagram using the TUSB217EVM in the following setup: PC test port --> short USB cable --> TUSB217EVM --> 5 m cable --> USB2 test fixture --> Scope. Keep in mind that results will vary with cable quality, cable gauge and PC performance without redriver.
Hi Cyan,
If you are looking for the power consumption at 5V this can be found in section 6.5 Electrical Characteristics, Power of the datasheet. ICC specs apply at Vcc =5V. Specs are also valid for Ta within the Recommended Operating Conditions.
