Part Number: TUSB7340
Our customer used TUSB7340 with Linux system, and sometimes appear below errors during insertion & plug operation. Could you please help to analyze?
Best regards
Kailyn
Best regards
Kailyn
Hi JMMN,
Thank you for your reply.
As the customer said, there were three times of the USB port problems. The first time is that the UART communication is well one all day, and the next morning has still be used, but when he plugged and inserted it again, he found that the error code under the system, and the four USB ports are all failed. Another time is after he copied the data with U disk, it appeared the error code under the system, and he four USB ports are all failed.
Best regards
Kailyn
