DP83TD510E-EVM:SPE cable of 1000m or more
Other Parts Discussed in Thread: DP83TD510E-EVM, DP83TD510E
We are verifying SPE using two sets of DP83TD510E-EVM.
I was able to confirm communication up to a cable distance of 1,000 m, but I could not communicate at 1,200 m.
We are expecting that communication will be possible even with a 1,200m cable,since the DP83TD510E is compatible with a 2,000m cable.
What you want to check
1) Is it possible to use a cable longer than 1,000 m with the DP83TD510E-EVM?
2) If you can use a cable of 1,000 m or more with DP83TD510E-EVM, would you tell me if there are any operations (register settings, etc.) that you should be careful about?
Reference material
1) DP83TD510E-EVM User’s Guide
www.tij.co.jp/.../snlu271
2) DP83TD510E data sheet
www.tij.co.jp/.../dp83td510e
    To answer your questions:
    1. Yes we have seen cables reach greater than 1700m with the Siemens 6XV1830-5EH10 cable.
    2. Some additional setting to reach this cable length are noted in this Application Note:
    Please note, after additional testing, the datasheet was updated to include a cable reach up to 2000 meters. I will check internally if additional settings were needed to extend this cable reach. Please review the Application Note until I am able to provide further feedback.
    Thank you,
    Nikhil
  • Hi Nikhil,
    When I fixed Master / Slave and changed it to 2.4 Vpp, I was able to confirm that communication of 2000 m or more was possible.
    I also attach the script I used.
    begin
    000d 001F
    000e 001f
    000d 401f
    000e 8000 //hard reset
    000d 0007
    000e 0200
    000d 4007
    000e 0000 //disable autoneg MMD 07
    000d 0001
    000e 0834
    000d 4001
    000e 4000 //Force Master Mode MMD 01
    000d 0001
    000e 08f6
    000d 4001
    000e 1000 //Force 2.4V swing MMD 01
    000d 001F
    000e 0608
    000d 401f
    000e 003b //disable_0_transition
    000d 001F
    000e 0862
    000d 401f
    000e 39f8 //AGC Gain during Autoneg
    000d 001F
    000e 081a
    000d 401f
    000e 67c0 //deq offset for 1V swing
    000d 001F
    000e 081c
    000d 401f
    000e fb62 //deq offset for 2.4V swing
    000d 001F
    000e 0830
    000d 401f
    000e 05a3 //Enable energy lost fallback
    000d 001F
    000e 0855
    000d 401f
    000e 1b55 //MSE Threshold change
    000d 001F
    000e 0831
    000d 401f
    000e 0403 //energy detect threshold
    000d 001F
    000e 0856
    000d 401f
    000e 1800 //good1 MSE threshold change
    000d 001F
    000e 0857
    000d 401f
    000e 8fa0 //Enable fallback to phase 1 on watchdog trigger
    000d 001F
    000e 0871
    000d 401f
    000e 000c //TED input changed to slicer_in without FFE
    000d 001F
    000e 0883
    000d 401f
    000e 022e //Enable Rx Filter, Change PGA threshold for Short Cable detection
    000d 001F
    000e 0402
    000d 401f
    000e 1800 //Adjusr LD swing
    000d 001F
    000e 0878
    000d 401f
    000e 2248 //Change PI up/down polarity
    000d 001F
    000e 010c
    000d 401f
    000e 0008 //tx filter coefficient
    000d 001F
    000e 0112
    000d 401f
    000e 1212 //tx filter scaling factor
    000d 001F
    000e 0809
    000d 401f
    000e 5c80 //AGC retrain
    000d 001F
    000e 0803
    000d 401f
    000e 1529 //Master Ph1 Back-off
    000d 001F
    000e 0804
    000d 401f
    000e 1a33 //Master Ph1 Back-off
    000d 001F
    000e 0805
    000d 401f
    000e 1f3d //Master Ph1 Back-off
    000d 001F
    000e 0850
    000d 401f
    000e 045b //hybrid gain & delay
    000d 001F
    000e 0874
    000d 401f
    000e 6967 //kp step 0 for master
    000d 001F
    000e 0852
    000d 401f
    000e 7800 //FAGC init gain
    000d 001F
    000e 0806
    000d 401f
    000e 1e1e //Master/Slave Ph2 Back-off
    000d 001F
    000e 0807
    000d 401f
    000e 2525 //Master/Slave Ph2 Back-off
    000d 001F
    000e 0808
    000d 401f
    000e 2c2c //Master/Slave Ph2 Back-off
    000d 001F
    000e 0850
    000d 401f
    000e 0590 //Hybrid Gain/Delay Code
    000d 001F
    000e 0827
    000d 401f
    000e 4000 //Echo Fixed Delay
    000d 001F
    000e 0849
    000d 401f
    000e 0fe4 //Hybrid Cal enable
    000d 001F
    000e 084b
    000d 401f
    000e 04b5 //Echo Score Sel
    000d 001F
    000e 001f
    000d 401f
    000e 4000 //soft reset
    end
    begin
    000d 001f
    000e 001f
    000d 401f
    000e 0000 //hard reset
    000d 0007
    000e 0200
    000d 4007
    000d 0001
    000e 0834
    000d 4001
    000e 0000 //Force Slave Mode MMD 01
    000d 0001
    000e 08f6
    000d 4001
    000d 001f
    000e 0608
    000d 401f
    000d 001f
    000e 0862
    000d 401f
    000d 001f
    000e 081a
    000d 401f
    000d 001f
    000e 081c
    000d 401f
    000d 001f
    000e 0830
    000d 401f
    000d 001f
    000e 0855
    000d 401f
    000d 001f
    000e 0831
    000d 401f
    000d 001f
    000e 0856
    000d 401f
    000d 001f
    000e 0857
    000d 401f
    000d 001f
    000e 0871
    000d 401f
    000d 001f
    000e 0883
    000d 401f
    000d 001f
    000e 0402
    000d 401f
    000d 001f
    000e 0878
    000d 401f
    000d 001f
    000e 010c
    000d 401f
    000d 001f
    000e 0112
    000d 401f
    000d 001f
    000e 0809
    000d 401f
    000d 001f
    000e 0803
    000d 401f
    000d 001f
    000e 0804
    000d 401f
    000d 001f
    000e 0805
    000d 401f
    000d 001f
    000e 0850
    000d 401f
    000d 001f
    000e 0874
    000d 401f
    000d 001f
    000e 0852
    000d 401f
    000d 001f
    000e 0806
    000d 401f
    000d 001f
    000e 0807
    000d 401f
    000d 001f
    000e 0808
    000d 401f
    000d 001f
    000e 0850
    000d 401f
    000d 001f
    000e 0827
    000d 401f
    000d 001f
    000e 0849
    000d 401f
    000d 001f
    000e 084b
    000d 401f
    000d 001f
    000e 001f
    000d 401f
    end
    Thank you for your confirmation.
