Part Number: DS160PR410
I would like to ask if DIP switches can be used for PIN's with L0-L3 levels rather than headers as shown on the reference designs?
Alexandros
Alexandros
Hi Alexandros,
Sure yes this can be used. Please note correct Resistor values - as noted in data sheet - must be used along with dip switch setting. Good thing about headers is that you can use one header to set certain level. Using dip switch, there is a possibility that two dip switches could be set at the same time.
Regards,, Nasser
Regards,, Nasser
