Part Number: AM26LV31E-EP
In table 6.5 Electrical Characteristic of the data sheet regarding Ios short circuit output current can you clarify elaborate more about output being shorted to either VCC or Ground and to avoid this possibility when one output is not used? For instance if we do not use one diff pair output, then, pulling them up or down thru a resistor appears to be appropriate practice. What resistance value do you recommend? What is best practice for treating an unused output?
Thank you,
HSG
