Part Number: DS90UB934-Q1EVM
We have DS90UB934-Q1EVM, Is it possible to receive the video output on HDMI screen ?
is there a converter for this ? On which screen can we visualize these LVCMOS Video Output ?
Hi Hanna,
The output will be in parallel interface. With the EVM alone, you will not be able to output on HDMI screen. You may be able to find a parallel to HDMI converter online but we don't have any suggestions.
Jiashow
we don't wanna any specific model as a suggestion , just need the name of a cable or an adapter that might be used or even an image,
Note : it doesn't have to be an HDMI, it can be an analog end.
Hi Hanna,
The DVP interface requires a processor to decode DVP data to output onto a display. You may need to look into a processor and an adaptor board to achieve this.
Jiashow
Okay is there another evaluation Ti provides to decode this parallel digital output to a format we can visualize here ?
Hi Hanna,
If you're using a DVP camera, you'll need a processor to decode the DVP camera. You won't be able to see the digital output without processing.
Jiashow
The Question is : what is this processor or the Evaluation kit that can decode this, Is that processor depend completely on the camera sensor type or the DVI is almost same for most of them
Hi Hanna,
The interface for the UB934 is parallel output; therefore, if you want to convert from parallel output to HMDI output, you need to video converter such as some kind of video processor. Below is the example of the video processor.
Hope this helps. Let me know if you have any questions.
Aaron
