Part Number: DP83848I
Our customer met a question about the DP83848I application, his application diagram is as following:
The PC controls the relay on/off by the MCU of the device board, and then the relay control the AC contactor on/off.
The question is when controlling the AC contactor on/off, sometimes it would appear the Network communication interruption phenomenon. The test method is to control the AC contactor on/off with one per second frequency continuously, and each 10 minutes would appear the communication interruption, and also appear ping packet loss. But if he didn't control the AC contactor, the network is stable and work normally. (note: MCU work normally when network interrupt). And this time MCU couldn't receive data from DP83848, and the yellow LED of RJ45 couldn't bright.
Attached is the register data, when the network interrupt, the register 0X12 is always 0X0200, and the register 0X14 is 0X00ff. What is DP83848 status at this time? If he inserted and plugged the cable, the network would recover normally, or interrupt 5~6 seconds and then recover automatically.
Could you please help to analyze what is the main problem, EMI or the register configuration?
Dp83848 register during communication
Register Address: |
0x01 |
0x04 |
0x05 |
0x06 |
0x07 |
0x10 |
0x11 |
0x12 |
0x14 |
0x15 |
0x16 |
0x17 |
0x18 |
0x19 |
0x1a |
0x1b |
0x1d |
Communication Normally |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
AC contactor off/on (frequency about once per second continuous ) |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
200 |
b8 |
0 |
100 |
2d |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
5b |
0 |
100 |
2d |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
59 |
0 |
100 |
2d |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
25 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2c |
0 |
100 |
25 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
25 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
5b |
0 |
100 |
2d |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
25 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2f |
0 |
100 |
2d |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
5b |
0 |
100 |
25 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2e |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2e |
0 |
100 |
25 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
25 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
2d |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
25 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
25 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2b |
0 |
100 |
25 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
1 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2f |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
2d |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
21 |
0 |
100 |
25 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
415 |
0 |
0 |
5a |
0 |
100 |
29 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
615 |
0 |
0 |
0 |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
Network interrupt |
786d |
101 |
cde1 |
0d |
2801 |
e15 |
0 |
200 |
ff |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
e15 |
0 |
200 |
ff |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
e15 |
0 |
200 |
ff |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
e15 |
0 |
200 |
ff |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
e15 |
0 |
200 |
ff |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
e15 |
0 |
200 |
ff |
0 |
100 |
2d |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
e15 |
0 |
200 |
ff |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
e15 |
0 |
200 |
ff |
0 |
100 |
25 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
e15 |
0 |
200 |
ff |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
e15 |
0 |
200 |
ff |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
e15 |
0 |
200 |
ff |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
e15 |
0 |
200 |
ff |
0 |
100 |
29 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
e15 |
0 |
200 |
ff |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
e15 |
0 |
200 |
ff |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
e15 |
0 |
200 |
ff |
0 |
100 |
21 |
0 |
8021 |
904 |
0 |
6011 |
786d |
101 |
cde1 |
0d |
2801 |
e15 |
0 |
200 |
ff |
0 |
100 |
2d |
0 |
8021 |
904 |
0 |
6011 |
Best regards
Kailyn
