Part Number: TUSB8041
Other Parts Discussed in Thread: TUSB8042, TUSB8042A
Hi Team,
Our customer is using TUSB8041 to work with Novatek SoC and added 100nF AC coupling capacitors on USB_SSRX_UP pins for TUSB8041, but they found that sometimes it will cause USB3.0 communication failure. But if we removed the AC coupling capacitors on USB_SSRX_UP pins, it will work fine.
As the Novatek side will ask customer to add these AC coupling capacitors on the USB_SSRX_UP pins, can you help to check if we can add them? And what's the recommended value if needed?
Thanks a lot!
