Part Number: DS90UH940-Q1
Hi, Team,
In the datasheet p74, it is stated for CSICFG1 addr6Bh bit1 INV_VS that "When set, the VS received from the digital receiver will be inverted. Because the CSI logic works on active-high VS, this bit is typically set when the VS from the data source is active-low".
Which waveform would be the "active-low" mentioned in the above sentence?
The above shows the VSYNC signal.
We think it is No.2, but want to double-check your team's opinion.
Masaru
