Part Number: DP83822IF
Other Parts Discussed in Thread: DP83822I
Hello experts,
I have question about DP83822IF behavior when disable 100BASE-FX.
From datasheet, the difference between DP83822IF and DP83822I is only FX support.
So, if DP83822IF disable FX support function, DP83822IF can be used same as DP83822I?
To do so, we need to set 29pin "OPEN"(datasheet P48). Is my understanding correct?
I would appreciate if you would give me reply.
Thanks and best regards,
Ryo Akashi
