Part Number: TPS65987D
We are using TPS65987D in our solution as Android Accessory for power swapping feature. We are testing the solution with different PD enabled mobiles (Samsung S20 FE and Google Pixel 2).
Samsung mobile setup is working fine in both transition Source to Sink and Sink to Source but with Google pixel sometimes we are seeing failure in below scenario
1. First power up the Accessory device.
2. Then connect the accessory to mobile phone.
So in this case Accessory should become source while mobile as sink and taking power from accessory to charge itself.
with Samsung phone no issue observed but in case of Google pixel some times VBUS not getting stable and it just keep toggling ON and OFF.
After debugging using TI Application Customization tool, we observed Accessory PD gives error as PEState_ErrorRecovery.
Attaching logs both when it works fine and when it fails.
Can you please provide some inputs on condition that can create the issue of PEState_ErrorRecovery?
Port 1 Module 31 0x1ff = UNKNOWN
Port 0 Type-C 0x65 = COMMON_STATE_ATTACHWAIT_SNK
Port 0 Type-C 0x66 = COMMON_STATE_UNATTACHED_SNK
Port 0 VBUS 0xcd = VBUSState_OVP_UVP
Port 0 VBUS 0xb6 = VBUSState_GOOD_RISING
Port 0 Type-C 0x61 = COMMON_STATE_ATTACHED_SNK
Port 0 BC 1.2 0xd = CHARGER_DCP_ADVERTISEMENT_COMPLETE
Port 0 INT 0x19 = DATA_STATUS_UPDATE
Port 0 INT 0x3 = PLUG_INSERT_OR_REMOVAL
Port 0 PD 0x2 = PEState_LaunchPolicyEngine
Port 0 PD 0x21 = PEState_Sink_Startup
Port 0 VBUS 0xcc = VBUSState_MON_HILO
Port 0 VBUS 0x90 = VBUSState_MON_HI
Port 0 PD 0x22 = PEState_Sink_Discovery
Port 0 PD 0x24 = PEState_Sink_WaitForCapabilities
Port 0 BC 1.2 0x4 = CHARGER_DETECTION_COMPLETE
Port 0 Protocol 0xc5 = PRState_RX_BUF_RDY
Port 0 PD 0x26 = PEState_Sink_EvaluateCapability
Port 0 PD 0x27 = PEState_Sink_SelectCapability
Port 0 Protocol 0xc8 = PRState_TXDONE
Port 0 PD 0xbf = PEState_ErrorRecovery
Port 0 PD 0x1 = PEState_CableTypeDetect
Port 0 Type-C 0x5 = SRC_STATE_ERROR_RECOVERY
Port 0 VBUS 0x91 = VBUSState_MON_LO
Port 1 PD 0x1 = PEState_CableTypeDetect
Port 1 Type-C 0x0 = SRC_STATE_DISABLED
Port 0 BC 1.2 0x0 = CHARGER_DETECTION_INIT
Port 0 BC 1.2 0x11 = SECONDARY_DETECTION_WAIT
Port 0 BC 1.2 0xe = CHARGER_DETECTION_DISABLED
Port 0 BC 1.2 0x2 = PRIMARY_DETECTION
Port 0 Protocol 0xc0 = PRState_SQUELCH_ACTIVE
Port 0 Protocol 0xc1 = PRState_SQUELCH_IDLE
Port 0 Protocol 0xcb = PRState_RECEIVED_GOODCRC
Port 0 PD 0x28 = PEState_Sink_TransitionSink
Port 0 PD 0x29 = PEState_Sink_TransitionSink_PS_RDY
Port 0 PD 0x2a = PEState_Sink_Ready
Port 0 PD 0xd = PEState_GiveSinkCap
Port 0 PD 0x5c = PEState_UFP_VDM_Send_Identity
Port 0 PD 0x34 = PEState_PD_Send_Custom_Message
Port 0 PD 0x32 = PRState_Sink_SinkTxOk
Port 0 PD 0x36 = PEState_PRS_Send_PR_Swap
Port 0 PD 0x3a = PEState_PRS_TransitionToOff
Port 0 PD 0x3b = PEState_PRS_TransitionToOff_Sink
Port 0 VBUS 0xb7 = VBUSState_GOOD_FALLING
Port 0 PD 0x38 = PEState_PRS_AssertRp
Port 0 PD 0x3e = PEState_PRS_SourceOn
Port 0 PD 0x3f = PEState_PRS_SourceOn_PS_RDY
Port 0 Type-C 0x60 = COMMON_STATE_ATTACHED_SRC
Port 0 PD 0x13 = PEState_Source_Startup
Port 0 PD 0x99 = PEState_PLUG_Send_SoftReset_Request
Port 0 PD 0x96 = PESTATE_SRC2PLUG_VDM_Identity_Request
Port 0 PD 0x98 = PESTATE_SRC2PLUG_VDM_Identity_NAKed
Port 0 PD 0x14 = PEState_Source_Startup_Continue
Port 0 PD 0x16 = PEState_Source_SendCapabilities
Port 0 PD 0x19 = PEState_Source_NegotiateCapability
Port 0 PD 0x1b = PEState_Source_TransitionSupply_Accept
Port 0 PD 0x1c = PEState_Source_TransitionSupply
Port 0 PD 0x1e = PEState_Source_TransitionSupply_SetAlarmsNew
Port 0 PD 0x1f = PEState_Source_TransitionSupply_PS_RDY
Port 0 PD 0x17 = PEState_Source_Ready
Port 0 Protocol 0x30 = PRState_Source_SinkTxOk
Port 0 PD 0x31 = PRState_Source_SinkTxNG
Port 0 Module 4 0xe0 = UNKNOWN
Port 0 Module 4 0xe1 = UNKNOWN
Port 0 Module 15 0x8 = UNKNOWN
Port 0 Module 15 0x108 = UNKNOWN
Port 1 PD 0x8 = PEState_SendSoftReset_Accept
Port 1 Module 2 0x110 = UNKNOWN
Port 1 Module 5 0x110 = UNKNOWN
Port 0 Module 11 0x110 = UNKNOWN
Port 0 Module 24 0x8 = UNKNOWN
Port 0 Module 0 0x110 = UNKNOWN
Port 0 Module 1 0x108 = UNKNOWN
Port 0 Module 12 0x10a = UNKNOWN
Port 1 Module 19 0xa = UNKNOWN
Port 1 Sleep 0x0 = SLEEP_STATE_AWAKE
Port 0 Module 8 0x112 = UNKNOWN
Port 0 Module 8 0x12 = UNKNOWN
Thanks & Regards,
Amol M Shrotri
