Part Number: SN65HVD257
I am using SN65HVD657 IC in my design like a bus. 150 nodes connected in the bus. I want to calculate the power consumption. So if any faut occur means datasheet showing 180mA is the maximum fault current. Whether this current flows through all 150 IC? If yes means i need to consider VCC*Fault current*150.
Kindly reply
Warm regards,
Monisha OM
