Part Number: TPS65987D
Other Parts Discussed in Thread: BQ25703, TPS65987, BQ25713, TPS25750
I am following the the application note SLVAE18 whereby I am designing a USB-C PD controller connected to a BQ25703 via I2C.
However the battery I am using is a Smart battery with an SMBus. I would like to read the temperature from the Smart battery via the SMBus and be able to shutdown the charger if an over/under temp condition occurs.
Can I use an I2C port on the TPS65987 to read this temp data an act accordingly by shutting off the charger? Do you have any examples?
