XIO2001: XIO2001 not detected by PEX8732 (PCIe Gen3)
Part Number: XIO2001
Other Parts Discussed in Thread: DS80PCI402
we have a problem with the XIO2001 not detected by a PEX8732 Gen3 PCIe Switch.
We have two different board designs that both show the same behaviour.
We found that the XIO2001 continuously generates PCI resets (approx. every 60ms) in this case.
Other PCIe-to-PCI bridges, like Pericom PI7C9X111SL work fine with the PEX8732.
With other (Gen2) PCIe-Switches, our XIO2001 based designs work fine.
Are you aware of any compatibility issues between XIO2001 and PEX8732?
Are there any known issues with the XIO2001 and Gen3 link partners?
Any idea how to get the XIO2001 working with the PEX8732?
Looking forward to your answers,
Niels
  • Hi Niels,
    I checked XIO2001 known errata. The only thing that could be related to what you are observing perhaps is CLKREQ# not functioning properly in Gen3 power managed states. The thought is that CLKREQ# could be causing this continuous PERST# generation. Maybe the workaround for this could take care of the issue you are seeing.
    Regards,, Nasser
  • Hello Nasser,
    unfortunately, it is the PCI-Reset# which is continiously generated by the XIO2001.
    (PCI, this old, traditional, parallel interface)
    The PCI-Express Reset Signal PERST# behaves as expected. A short "low" period during power-up, and then it transitions to a stable "high".
    Here is a closer view on the pulsing PCI-Reset#:
    PCIe-REFCLK and PCI-Clk are both running with correct frequencies, even during PCI-Reset# transitions:
    Do you still think that
    "Set the FORCE_CLKREQ bit to disable CLKREQ support on the pci-express bus."
    could be the solution?
    By the way, we have an EEPROM connected to the XIO2001, but it is empty.
    Does TI provide any tools to program the EEPROM and a recommended EEPROM content?
    Regards, Niels
  • 'WinROM 3 EEPROM Data File
    'DEVICE ID: 8240104C	SILICON REV: 00
    'Created 1/15/2009 4:38:21 PM
    000	00	00000000
    001	25	00100101
    002	00	00000000
    003	00	00000000
    004	00	00000000
    005	00	00000000
    006	5F	01011111
    007	02	00000010
    008	00	00000000
    009	86	10000110
    00A	00	00000000
    00B	00	00000000
    00C	00	00000000
    00D	40	01000000
    00E	00	00000000
    00F	01	00000001
    010	00	00000000
    011	00	00000000
    012	00	00000000
    013	08	00001000
    014	01	00000001
    015	12	00010010
    016	00	00000000
    017	80	10000000
    018	20	00100000
    019	14	00010100
    01A	32	00110010
    01B	00	00000000
    01C	00	00000000
    01D	00	00000000
    01E	00	00000000
    01F	00	00000000
    020	43	01000011
    021	04	00000100
    022	08	00001000
    023	7F	01111111
    024	00	00000000
    025	C0	11000000
    026	00	00000000
    027	80	10000000
    028	FF	11111111
    029	FF	11111111
    02A	FF	11111111
    02B	FF	11111111
    02C	FF	11111111
    02D	FF	11111111
    02E	FF	11111111
    02F	FF	11111111
    030	FF	11111111
    031	FF	11111111
    032	FF	11111111
    033	FF	11111111
    034	FF	11111111
    035	FF	11111111
    036	FF	11111111
    037	FF	11111111
    038	FF	11111111
    039	FF	11111111
    03A	FF	11111111
    03B	FF	11111111
    03C	FF	11111111
    03D	FF	11111111
    03E	FF	11111111
    03F	FF	11111111
    040	FF	11111111
    041	FF	11111111
    042	FF	11111111
    043	FF	11111111
    044	FF	11111111
    045	FF	11111111
    046	FF	11111111
    047	FF	11111111
    048	FF	11111111
    049	FF	11111111
    04A	FF	11111111
    04B	FF	11111111
    04C	FF	11111111
    04D	FF	11111111
    04E	FF	11111111
    04F	FF	11111111
    050	FF	11111111
    051	FF	11111111
    052	FF	11111111
    053	FF	11111111
    054	FF	11111111
    055	FF	11111111
    056	FF	11111111
    057	FF	11111111
    058	FF	11111111
    059	FF	11111111
    05A	FF	11111111
    05B	FF	11111111
    05C	FF	11111111
    05D	FF	11111111
    05E	FF	11111111
    05F	FF	11111111
    060	FF	11111111
    061	FF	11111111
    062	FF	11111111
    063	FF	11111111
    064	FF	11111111
    065	FF	11111111
    066	FF	11111111
    067	FF	11111111
    068	FF	11111111
    069	FF	11111111
    06A	FF	11111111
    06B	FF	11111111
    06C	FF	11111111
    06D	FF	11111111
    06E	FF	11111111
    06F	FF	11111111
    070	FF	11111111
    071	FF	11111111
    072	FF	11111111
    073	FF	11111111
    074	FF	11111111
    075	FF	11111111
    076	FF	11111111
    077	FF	11111111
    078	FF	11111111
    079	FF	11111111
    07A	FF	11111111
    07B	FF	11111111
    07C	FF	11111111
    07D	FF	11111111
    07E	FF	11111111
    07F	FF	11111111
    080	FF	11111111
    081	FF	11111111
    082	FF	11111111
    083	FF	11111111
    084	FF	11111111
    085	FF	11111111
    086	FF	11111111
    087	FF	11111111
    088	FF	11111111
    089	FF	11111111
    08A	FF	11111111
    08B	FF	11111111
    08C	FF	11111111
    08D	FF	11111111
    08E	FF	11111111
    08F	FF	11111111
    090	FF	11111111
    091	FF	11111111
    092	FF	11111111
    093	FF	11111111
    094	FF	11111111
    095	FF	11111111
    096	FF	11111111
    097	FF	11111111
    098	FF	11111111
    099	FF	11111111
    09A	FF	11111111
    09B	FF	11111111
    09C	FF	11111111
    09D	FF	11111111
    09E	FF	11111111
    09F	FF	11111111
    0A0	FF	11111111
    0A1	FF	11111111
    0A2	FF	11111111
    0A3	FF	11111111
    0A4	FF	11111111
    0A5	FF	11111111
    0A6	FF	11111111
    0A7	FF	11111111
    0A8	FF	11111111
    0A9	FF	11111111
    0AA	FF	11111111
    0AB	FF	11111111
    0AC	FF	11111111
    0AD	FF	11111111
    0AE	FF	11111111
    0AF	FF	11111111
    0B0	FF	11111111
    0B1	FF	11111111
    0B2	FF	11111111
    0B3	FF	11111111
    0B4	FF	11111111
    0B5	FF	11111111
    0B6	FF	11111111
    0B7	FF	11111111
    0B8	FF	11111111
    0B9	FF	11111111
    0BA	FF	11111111
    0BB	FF	11111111
    0BC	FF	11111111
    0BD	FF	11111111
    0BE	FF	11111111
    0BF	FF	11111111
    0C0	FF	11111111
    0C1	FF	11111111
    0C2	FF	11111111
    0C3	FF	11111111
    0C4	FF	11111111
    0C5	FF	11111111
    0C6	FF	11111111
    0C7	FF	11111111
    0C8	FF	11111111
    0C9	FF	11111111
    0CA	FF	11111111
    0CB	FF	11111111
    0CC	FF	11111111
    0CD	FF	11111111
    0CE	FF	11111111
    0CF	FF	11111111
    0D0	FF	11111111
    0D1	FF	11111111
    0D2	FF	11111111
    0D3	FF	11111111
    0D4	FF	11111111
    0D5	FF	11111111
    0D6	FF	11111111
    0D7	FF	11111111
    0D8	FF	11111111
    0D9	FF	11111111
    0DA	FF	11111111
    0DB	FF	11111111
    0DC	FF	11111111
    0DD	FF	11111111
    0DE	FF	11111111
    0DF	FF	11111111
    0E0	FF	11111111
    0E1	FF	11111111
    0E2	FF	11111111
    0E3	FF	11111111
    0E4	FF	11111111
    0E5	FF	11111111
    0E6	FF	11111111
    0E7	FF	11111111
    0E8	FF	11111111
    0E9	FF	11111111
    0EA	FF	11111111
    0EB	FF	11111111
    0EC	FF	11111111
    0ED	FF	11111111
    0EE	FF	11111111
    0EF	FF	11111111
    0F0	FF	11111111
    0F1	FF	11111111
    0F2	FF	11111111
    0F3	FF	11111111
    0F4	FF	11111111
    0F5	FF	11111111
    0F6	FF	11111111
    0F7	FF	11111111
    0F8	FF	11111111
    0F9	FF	11111111
    0FA	FF	11111111
    0FB	FF	11111111
    0FC	FF	11111111
    0FD	FF	11111111
    0FE	FF	11111111
    0FF	FF	11111111
    'DATA FILE FORMAT: <HEX ADDRESS><TAB><HEX DATA>. EVERYTHING AFTER <DATA> IS IGNORED.
    'USE <'> FOR IN-LINE COMMENTING.
    'DATA FILE PARSING STOPS AT FIRST BLANK LINE.
    Hi Neil,
    1). You can try this - set the Force_CLKREQ bit. I haven't been able to find an errata pointing to the issue you are seeing and it is worth a shot.
    2). Also, I am attaching EEPROM file or content to this email. Perhaps the initialization is different and it may help us here. Please note extension of the file is WR3 but since i was not able to attached to this case with WR3 extension i had to change this to txt.
    Regards,, Nasser
  • Hello Nasser,
    thanks for posting the EEPROM content.
    We programmed our XIO2001 with your content, but the error stayed unchanged.
    As an additional test, we interposed a Cabled-PCIe connection between XIO2001 and PEX8732, and everything was fine.
    Sounds like an signal integrity problem.
    The cabled-PCIe "interposer" consisted of redrivers only. The signal chain during this test was as follows:
    PEX8732 ---> DS80PCI402 ---> PI2EQX5804 ---> DS80PCI402 --> XIO2001
    Any idea why interposing a redriver changes the behaviour?
    Regards, Niels
  • Hi Niels,
    Yes this seems to be a signal integrity issue.
    1). Do you see the problem if you just take out DS80PCI402 before the XIO part and leave the other one?
    2). DS80PCI402: Are you using evaluation board for this part or this is part of the interposer?
    Regards,,, Nasser
  • Hi Nasser,
    as "interposer", we used a cabled-PCIe extension. It consists of:
    • TPCE278
    • OSS-XMC-HIB25-X8
    • OSS-PCIe-CBL-x8-xM
    • OSS-PCIe-ECA-x8
    Due to the different form factors of the boards, I am not able to "snip out" one of the redrivers.
    As you can see fron the listing above, the DS80PCI402 is located on two different boards of different vendors.
    Are there any options to "tune" the XIO2001's receiver equaliser or anything similar?
    Regards, Niels
  • Hi Niels,
    Checked and there is not a register for signal conditioning. One thought crossed my mind, is it possible to force certain preset on this switch ? I am wondering there could be a setting that would open up the eye more - to some extend do the job of equalization but on the TX side.
    Regards,, Nasser
  • Nasser,
    tuning the switch's transmitter is an alluring ude. But the board holding the switch is not from us, so I can't say if it is possible to tune the transmitter or not. I will try to find out on monday.
    Regards, Niels
