Part Number: TCAN4551-Q1
Hi to all,
I would be interested in using the TCAN4551 without using the internal main regulator.
I would like to exclude the Vbatt supply bypassing the main internal regulator by feeding the chip directly with the + 5V voltage instead of Vbatt supply from the Vsup pin.
Do you think it is possible to supply the TCAN4551 by directly injecting the +5V into the VCCFLTR pin and then leaving the Vsup pin floating?
Is this a safe working condition or does it risk compromising its reliability?
Thanks for your attention,
Fabio
