Part Number: DS250DF410
Hi - I'm considering using the DS250DF410 for the M-PHY protocol and have some questions:
- What is the minimum frequency (ie low frequency cut-off)?
- Can this part be used as a "basic" amplifier? In other words, can I pass a PRBS signal with analog gain through to the output. I see that the raw non-retimed data can be used, but are there any other reasons why this part can't be used as an amplifier?
- The minimum input amplitude required to assert signal detect is specified at 196 mVppd. Related to the question above, if I input a small signal (say ~10mVppd, as an example), will the VGA, X-point, FIR, and driver function with small input amplitude?
Thanks!
Ned
