Part Number: TPS65988
Hi Team,
If PP1_OCCTimeoutEnable is set to 0(although it's not recommended),may I know if the OCP will be disabled?
Thanks and Best Regards!
Hao
Hi Team,
Hao
Hi Hao,
No this is only the enable for the timeout value, it will not disable the OCP completely.
Thank you,
Hari
Hi Hari,
If the timeout value is unlimited when PP1_OCCTimeoutEnable is set to 0, as TPS65988 has 5A internal MOSFET, does it mean that the OCP will never happen if the real current is less than 5A but higher than the PDO max current?
Hao
Hi Hao,
I will check into this with my team and let you know next week how this will be impacted.
Thank you,
Hari
