Part Number: DP83867CR
Hi Team,
We would like to ask your help regarding the customer's concern below.
We are developing an ethernet product and have found that we are unable to get our DP83867CR PHY to auto-negotiate, and we have found that the PHY has reported that channel C has reverse polarity. After much review, we are unable to determine why this is. Is there any errata associated with this problem?
I have attached a PDF of the ethernet page if you would like to confirm we have correctly connected the PHY to the RJ45 magnetics. It should be noted that we have installed the bootstrap resistors for Auto-Negotiation (R81 and R92) so that it is in mode 3.
We also have found some additional problems when looking at the PHY registers. Many of the registers do not have the default values stated in the Datasheet. This includes the PHY ID registers (PHYIDR1, PHYIDR2). They are both reading 0x0000.
Thank you for your support!
Danilo
