Part Number: DS90UB948-Q1
Hi team,
one question about DS90UB948 pattern.does the 947/948 pattern support the 2396*1094*60fps and below LCD spec?
I ask this is becasue customer use 948 pattern for 2396*1094*60fps resolution LCD , found the display jitter.
1. does the 974/948 support dual pixel 2396*1094*60fps LCD?
2. Can the 948 pattern generate this resolution video timing to help test this LCD? I found the OSC of 948 is 140M
3. The 947/941/949 OSC is 200MHz/800MHz, can we use M/N divider to generate 2396*1094*60fps video timing to help test this LCD? if yes, how to set this?
thank you
