Part Number: DS90UB926Q-Q1
Hi Team,
Is there a Serdes solution for 2 in and 1 out ?.
Take 926 as an example
The requirements are as follows
1. Serdes solution for 2 in and 1 out
or
2.Switch for 2 in and 1 out and connect to Serdes
Hi Team,
or
There are no FPD-Link devices that have 2 PARALLEL INTERFACE inputs, you can use a switch in front of the 926 to switch the input of the 926, but you must power down the device using the PDB pin between switching the device's input with.
Michael W.
Hi Team,
Do you have a suggested SCH or block diagram ?
This way I can better understand what you mean !
Hi Kygo,
If you use a mux you can use the block diagram 2 you posted in your question.
Michael W.
