SN65HVD10
Hi Support,
Just need some clarification. As per the datasheet Recommended operating condition is -7V to 12V.
Does it mean that at any given time between A & B, A can go as low as -7V and B can go as high as 12V at the same time or vice versa?
Thanks.
  • Aditya,
    No, it does not mean at any given moment these pins can go as low as -7V and as high as 12V. This parameter means that the bus pins can interpret voltages between this range in case there are ground or source shifts within the application.
    Please let me know if you have any other questions.
    Eric Hackett
