Part Number: TPS65987D
Dear Eric,
I noticed that the pin 25 (PP_CABLE) connects not 5V but 3.3V in the TPS65987-90EVM, while the datasheet says it is the 5V input. Does it work with 3.3V?
Thanks again,
Dear Eric,
Thanks again,
Hi Jeong,
It is recommended to attach 5V to the PP_Cable pin. This Pin is the supply for VCONN. VCONN would provide power to e-marked Type-C cables. Some e-marked cables are able to operate from 3.3V, but all can operate from 5V.
If this answers your question, PLEASE select This resolved my issue
Thank you,
Eric
Hi Jeong,
On the TPS65987-90EVM it was used since the 3.3V rail was readily available on the board. That's the only reason. 5V is the recommended voltage for the PP_Cable pin.
Thank you,
Eric
